As much as you may wish to believe it, a $35 spectrographic analysis isn't going to be able to discriminate what is the "best oil" for your engine. It's nowhere near the proper tool for generate comparative oil quality data - especially in the manner you're using it. You're not even close.
Okay, fair enough, but can you guide me then towards a better, more scientific process? Again, my goal is to make the right oil VISCOSITY choice for maximum engine protection based on facts rather than opinion.
I was thinking of the oil analysis showing me 1) how badly the oil has sheared down or otherwise meaningfully deteriorated in its protective ability, and 2) how much wear metals are in the oil. I figured the $35 oil analysis would shed light at least on those simple analytics and thereby help suggest whether a step up in viscosity might actually reduce engine wear.
I realize I’m probably both ignoring some factors and making some assumptions, but it seems there should be a better way than flipping a coin to decide whether to obey the CAFE-driven, 0W-20 factory mandate or move up to a 5w-30…probably PUP 5w-30 because, as others here have pointed out, is on the lower end of the viscosity scale for that grade.
I am now ruling out a switch to 5w-20 based on advice here that it would provide no meaningful difference in protection for my engine and its usage. So, at least I’m a troll with ears…LOL. I really am here to learn.
My thinking was, if an oil analysis showed no improvement in wear metals with a switch to 5w-30 PUP, I might consider trying and analyzing the 0w-20 QS Ultimate Protection Synthetic recommended previously in this thread because it is considerably higher in actual viscosity than the PUP 0w-20.
The only reason I’d do that (versus just sticking with PUP 5w-30) is to stay with the factory recommended weight. I care for my cars very well and always (quickly and easily) dispose of them in a private sale. I have the thought that a future buyer of this car years down the road might worry that I strayed from Toyota’s mandate to use 0w-20. I suppose most people wouldn’t even think to ask beyond oil change intervals, although some (sad) people are like me and might worry about it. But if the choice is between a future buyer’s potential worries and better actual engine protection, I adamantly choose the latter.
Recalling the facts and some very reasonable assumptions:
1. I drive quite conservatively (in the Lexus anyway) and never tow or carry a heavy load
2. Car is almost never started below freezing temperature; North Florida climate
3. I change oil and filter every 4000 miles which is also within about 6 months
4. I use Pennzoil Ultra Platinum which most would agree is at minimum a “good” oil
5. I have never observed any increase in oil level that would suggest fuel dilution
Regarding viscosity, I better understand now that there seems to be here a thicker camp, a thinner camp, and perhaps a makes-no-meaningful difference camp. So, if there is nothing in a $35 oil analysis that would help with choosing the best viscosity, is there a better way to make this decision other than “picking a camp?”
