Viscosity change with MMO in B&S Quantum?
RnR
Michigan, Thumb's Up!
Been successfully using MaxLife 10W30 in my 'ole B&S Quantum based push mower as was suggested here awhile back and just started adding a couple ounces of MMO to the sump a few weeks ago. Should I also be considering changing oil viscosity now that the MMO is in play?
Depends on the % of MMO. Sounds like you did not put enough in to make the switch, especially that you're in MI...
I'd leave it.
Since the viscosity is already a 30 weight and the sump is only 20 ounces, I'd step up to a 5W-40, HD40, or 10W-40 to combat dilution. As tpitcher said, however, it's Michigan, so it's really your call as long as the MMO isn't too heavily applied.
It's a mower...
The fact that you worry about means you probably change it more often than most. Some people I know/knew, the mower was lucky to see a change every few season! Besides, when it wear itself out after a few years, you can just keep adding and never have to worry about changing it again! Haha
I had my eye on about a 10% concentration, but with the recent talk about 40w thought I'd ask and see if I should be leary about getting a little too thin, especially with the smallish sump. I've got a ways to go before I've used up the MaxLife I already have, but will look at a slightly thicker formulation when the time comes. And yea... I change it a couple times during our summer period.
