MI_Roger
Originally Posted By: bubbatime
Originally Posted By: MI_Roger
Valves have never been adjusted. Only mow a 5,000 sq ft subdivision lot so not a lot of use compared to landscapers and large lots.
Assuming you have the flathead Briggs engine, there is no (easy) valve adjustment. The only way to adjust the valves is to take the (usually exhaust) valve out and grind the top until it is back into spec. Not a very common repair, but does happen sometimes.
Yeah, I knew they were having their fun with me. I almost responded back that the engine was running a custom built OHV head with roller followers. But that would have eliminated getting helpful suggestions from everyone else.
