Viscosity and hours between oil changes in small air cooled engines.
I was around hundreds of pieces of small air cooled ope when I worked in parks. The only time any engine had a problem was when it got north of 15,000 hours (!) or it just ran out of oil because no one checked the level. The only pattern of small engine failure I saw was with tennis court blowers with various 8 hp engines. They consumed a lot of oil since they’d always run at 100%, but they still last 20 years.
In my experience don't overthink it!! Mobil 1 0w30 if running at 20 Fahrenheit or below. The engine will pull start and run right off the bat. This weight is good up to 80 degrees ambient temps. 15w40 conventional or 10w40 Mobil 1, 15w50 Mobil 1 above 80 degrees for that. Look at my posts, I ran air cooled commercial mowers on a daily basis for many years. Never lost an engine due to the wrong oil weight. Most important is check the oil before you start it for the day. Top it off if it is even a bit low. Main thing is to keep the air filter clean, feed good quality fuel, toss in fuel stabilizer, keep a spare spark plug handy and have a quantity of oil in reserve. That is a win -win situation!!
In Houston I would run either 10w30, 30W, or if the engine is older and looser 15w40. Those Honda's with the aluminum cylinder will like the heavier viscosity after the bore has worn some.
Synthetic is a waste of money for small air cooled engines that have frequent oil change intervals, especially on a disposable aluminum bore engine. What you want is an oil with a high ZDDP content for protection of areas with thin oil films and against moisture. I recommened Shell Rotella T4. Cheap and easy to find.
Daily oil changes are insanity and abusive to the environment. Such an oil change regimen will not extend the engine's life beyond what it would be if the recommended intervals are followed. Furthermore, with the money wasted on daily synthetic oil changes you could buy a new Honda engine in a few years, a GX one with an iron sleeve and crank bearings. I bought a used Honda GX for my mower 15 years ago and after yearly conventional oil changes it still runs like new today. I measured compression this spring and it's the same as when I bought it. The rest of the mower is falling apart but that Honda GX is indestructable.
Honda owners manual recommends oil changes after 25 hours when used under heavy load or in high outside air temperatures. One a day is not insanity it is the manufacturers recommendation. I recycle the old oil and it only uses 12 ounces - abusive to the environment are you joking?
Hot as hell Houston after a hurricane is the intended use of my generator - so changing it everyday is what the manufacturer recommends.
It is hard to even find conventional 10w30 - Walmart doesn't even carry it in the store.
I can buy a 6 quart box of 10W30 Havoline (Chevron) for $19.98, synthetic blend is $19.98 and full synthetic is also $19.98.
Back a few years ago conventional oil was cheaper - not so much anymore -
If the price was the same - which it is with Havoline would you still use conventional oil? Why?
I have a supply of 30 weight, 5w40, 15w40 a bunch of 5w30 that I use in my truck and some 10w30 -56 quarts on hand - it will be a game time decision.
If cold then 5W30 or 10w30
If hot then straight 30
If really hot than 15w40
My Honda GCs all use 20 oz. 50 hour oil change intervals. Must be different in TX, here in MI the synthetic is significantly more expensive then conventional.
Looks like I was wrong about the OCI. If 25 hr intervals are what your manual says then do it.
I order oil from Walmart online - over $35 free shipping.
I just ordered some
Valvoline Premium Blue Synthetic Blend 10w30 Heavy Duty Diesel Engine Oil 1 GA from Walmart - $19.31​
I was low on 10W30 and this should be top notch stuff - regular price was $28.47. I am a cheap skate I like stuff on sale!
My Honda requires 50 hours or 6 months between changes for normal operation - run it a few hours here and there I guess - but requires more frequent service = every 25 when temps are hot and hard use - I think running it 24 hours straight only stopping to put gas in it is considered hard use. Look in the fine print I bet your Honda does too.
The way I look at it is even using higher cost oil it is less than $2 to change it - the 15W40 Chevron I bought on clearance it would only be $1.20 to change the oil.
If I run it a week straight that would be around $10 for oil - the gas I will use over 7 days will cost me $120. $10 doesn't seem like much.
With the Hondas I’ve found more issues with sensitivity to dusty fueling conditions. Every one I’ve had eventually develops a surging throttle condition, including my fairly new eu2000i. And in every case, cleaning the jet and installing a fuel filter makes the problem go away.
in the eu2000, there’s not much room for a filter, and the gas line is like 1/8”. I used a metal r/c filter designed for gas in it, and sealed its threads with seal-all as an extra precaution. Of course, when I did this, I also had to clean the jet because refueling on a dusty day is all it took.
with a heavily used mower, Mobil 1 5w30 was too thin when mulching in the southern heat here, and the engine was damaged over time. 10-30 solved the problem and the sparklies stopped showing up in the oil. It kept increasing start up smoke and consumption until I changed to 10-30 and it remained the same, but didn’t get worse, after that. Based on that, I won’t get thinner than a 10-30 in ope.
oh, and I’ve run that eu2000i nonstop for days following storms. Using synthetic oil, a week is fine as long as you check it.
Not all Honda engines use the same oil change maintenance schedule!
Your eu2000 is 100 hours or 6 months...
My EG2800i is 50 hours of 6 months under "normal" operation and 25 hours or 3 months under high outside temps or continuous / heavy use
But IMHO it is foolish to run your eu200i nonstop for a week without changing the oil. 168 hours is way over what Honda recommends.
It takes .42 of a quart so I will guess about $2 to change the oil.
Are you really that lazy and cheap?
I know changing the oil in the eu2000i is a little harder than some units - I have a similar 2000 watt unit and you have to pick it up and pour the oil out of the fill hole - but even the first time I did it it only took a few minutes.
The thing is - not changing the oil in your eu2000i will most likely not cause a total failure - it just reduces the life.
So do proper maintenance and it will last for decades of occasional use abuse it and it will start smoking, fouling plugs and lose output.
Your unit your choice - but I take a totally different approach to maintenance.
Many OPE manufacturers now recommend 5w30 - and since both 5w30 and 10w30 are 30 weight when hot it really only matters at start up.
The reason your mower was starting to smoke wasn't because you used 5w30 - it was because you didn't change the oil often enough. Oil gets contaminated and it causes excess wear on the rings - worn out rings from poor maintenance can be helped by using a heavier weight oil - but the damage is already done - using a heavier oil just helps cover up the problem.
I wouldn't either if my plan was to run it for 100 hours straight. But does changing it every day change the view?
While researching oil a while back I discovered that 5W30 has a higher viscosity at 100C than 10W30 -
Mobil 1 5W30 Kinematic Viscosity @ 100 C, mm2/s, ASTM D445 = 11.1
Mobil 1 10W30 Kinematic Viscosity @ 100 C, mm2/s, ASTM D445 = 10.4
High mileage Mobil 1 5W30 Kinematic Viscosity @ 100 C, mm2/s, ASTM D445 = 11.9 the 10W30 = 12.
I was thinking the 5W30 is an OK choice because it maintains a slightly higher viscosity at 100 C I am sort of pulling that out of my butt with no real scientific reason. I don't know much about HTHS and how it relates to viscosity at high temps -
I read some stuff about HTHS a while back - a lower number means it flows easier at extremely high temps - which gives you better fuel economy.
So 5W30 has a higher viscosity at 100 c VS 10W30
But 10W30 has a higher HTHS at 150 C VS 5W30
So does this mean running at high temps of 150 C the 5W30 would break down faster?
Do I care if I am changing the oil everyday? Right back where I started.
Does it really matter if one oil is 11.1 and the other is 10.4 at Kinematic Viscosity @ 100 C, or of one oil is 3.7 HTHS and the other is 3.5?
These differences seem small - when compared to something like a 0W20 with a Kinematic Viscosity @ 100 C, of 8.6 - IDN what the HTHS is but I will assume much lower than 3.7.
Deep stuff this oil anal
The 5w30s higher viscosity is from more Viscosity improvers additives . Under heat and load the oil with more viscosity improvers is thinner between the parts, if we want to over think. Clean fresh oil is happy oil and what is the recommended oil change interval in the manual and is there an oil filter?
no filter - I totally agree with your fresh oil is happy oil.
B&S states that the optimum oil is 5w30 full synthetic and that is what I use in my John Deere 20 HP B&S twin and 2200-watt B&S converter gen set. It' fun to try to outguess the manufactures but, in reality they have the long-term data, and we don't. JMO. Ed
I have spent a fair amount of time researching oil - trying to pick one for my air cooled Honda EG2800i generator. It will likely be used for a few days straight when outside temps are in the 90-98 degree range. (Houston area hurricane driven power outage)
On one hand I think - use a 5W30 full synthetic and change it at least every day or even every 15 - 20 hours.
On the other hand I think, use something like 10W40 / 15W40 - to provide better protection in the extreme heat.
My research leads me to the conclusion that higher viscosity oils like 15W40 are recommended by many because using 10W30 oils have resulted in oil related engine failures -
But is that because they used a 10W30 conventional oil and ran the generator hard for 4 or 5 days straight without an oil change when it was 95 degrees outside?
With a 15W40 they can run for a few days on the same oil and still avoid oil related engine problems - so they choose the higher viscosity oil.
Is a better choice to just change the oil more often?
If I start with the idea I will be changing the oil at least every day say 15-20 hours between oil changes -
Is a 5W30 synthetic a better choice over a 10W40 or 15W40 conventional oil or maybe even better than a 15W40 / 5W40 synthetic?
My theory is the 5W30 synthetic will provide a good oil film for at least a day - and since it is a lighter oil the engine will run cooler and maybe even have better fuel economy. Where a higher viscosity oil will cause the engine to work a little harder - making it run hotter and burn more fuel.
I totally understand why a heavier oil is required if you are going to go 150-200 hours between oil changes - the lighter oil will break down and stop providing the protection needed and it will result in a reduced engine life or total engine failure.
But does that change if you do at least daily oil changes?
It takes me 5 minutes to change the oil in my Honda EG2800i - I do it while refueling - the ~~16 ounces of oil costs less than $2 so I don't care about cost.
Maybe if I was running a commercial operation and I had a dozen air cooled engines running every day - a longer between oil changes system would be better - but that is not what I am doing.
So if 15-20 run hours between changes is the standard - which oil do you pick to keep your generator running for 4 days straight in 95 degree heat?
as ocd as we bitogers are i think you should go with what helps you sleep at night. i didn't and won't follow the honda recommended 10w30/sae30. will the 10w30 fail me if i used it? prob not because i would use rotella or delo 10w30. but since i've done continuous 50hr runs without checking the oil and refueling while my honda eu2000 is running, i trust 15w40 more. if in a pinch, and i were not able to find my HD 15w40 i'd run any 20W-50 or Mobil 1 15W-50 since it's widely available in my 95+ degree area. oh and if i had to in an emergency, where my oil stash were depleted, i'd sleep better knowing i had rotella 15w40 in the gennie.
I think the idea is to have an adequate oil film between moving parts - thicker is not always better - Why not use 15W60?
The thing is if I had to choose between too thick or too thin I would pick too thick every time - because if I was going to error thicker would be less destructive. But I am still kicking around what the best weight would be.
I have watched over the years as small engine manufacturing companies have gone from recommending SAE 30 to 10W30 and now 5W30 synthetic - and now the Kohler I just bought says #1 chose is 10W50.
More things change the more they stay the same!
my uncle ran non detergent compressor oil in his gennie during the last hurricane we had and the thing didn't die. i did change it out for rotella.
he only ran it 3 hrs everyday because he believes the genny needs "to rest"
I realize I am replying to a really old post, but do you know what type / weight of oil they ran?
There are some people that believe a non detergent oil is what an air-cooled engine like a generator should use - even though most owners manuals say specifically to NOT use a non detergent oil.
Ever wonder why major manufacturers like Honda call for 5W or 10W30 oil?
They have access to all the data - they have a vested interest in the engine lasting - and Honda is world renowned for the reliability of their small engines.
If 15W50 was really a better choice you would think they would jump on the bandwagon.
Same thing with Rotella or Delo - I know these are quality oils - but Honda - nor anyone else even shows them as acceptable substitutes.
It boggles the mind.
my uncle can't read so he asked the salesmen for 30 weight oil, he gave him ND sae30. with his gennie still kicking after running non detergent oil, maybe we're over thinking what oil to use?
that's a great question. my 2021 4Runner has a 0W-20 stateside recommendation but has a recommendation of 0W-20 thru 15w40 here in the island *Puerto Rico*. (same 4.0 1GR engine)
i use Valvoline Euro 5w30 and have used 10w30
