Originally Posted By: Shannow
Which allows the bulk oil temperature to exceed the thermostatically controlled coolant temperature, and under extreme conditions by a significant margin.
Thanks for reminding us of this. It's easy to forget that while the coolant circuit is fairly well governed to stay very close to a certain temperature (once warmed up, of course), oil temperatures fluctuate more and certainly aren't usually constrained quite to the narrow window that coolant temperatures are.
Of course, if one's driving a steady state 55 mph, one's oil temperature isn't apt to fluctuate much, even with a few degrees difference in ambient from test to test. In a similar vein, stepping on the gas isn't going to raise your coolant temperature to the point of overheating, either.
