I think the focus of this thread is to question whether the flashlight “test” indicates a filtration flaw in the Endurance filter, so any discussions about ISO testing and ranking seems irrelevant. The question remains …is flashing a light through this filter's bypass valve (when disassembled) enough to counter the actual filtering results of this filter intact?? Obviously the answer is a resounding NO!!!Yes, it's a "controlled" test for the most part, but as has been discussed in other threads, if every filter brand and model they tested was also ISO 4548-12 tested, would they all rank exactly in the the same order? I don't think so. When you look at the available official ISO efficiency numbers on some of the filters they have tested, they won't rank the same as their tests show. The Boss's efficiency ranking is a good example of that, and was discussed in the other various threads where this comes up.
That’s it in a nutshell.
