Sayjac
Thread starter
At least in the two anecdotes I c&ped that's what I found. As noted several times, there's not much pressure inside the can with the stamped spring anyway, very little or no extra pressure needed. Exert too much pressure and that flat spring will deform......Applying pressure to the leaf spring doesn't seem to reduce the gaps.
Spot On! And further, all meaningless/irrelevant to the OP pic finding. Also, the idea posited a couple times that the openings seen could/would actually mean oil flowing back to the dirty/upsteam side of the filter, in some "passive leakage" and "negative dp"....The BR testing isn't official, might not even be ranking them accurately without official ISO tests to verify. Send one out to an ISO test lab with $2000 and you'll get an answer.![]()
As the majority who frequent this forum know, it's simple. The opening seen is analogous to tear(s) in the media, the light seen indicates the areas of oil bypass. Not difficult to comprehend
As an aside, having watched and seen @53' Stude with his many c&p's, I now have a greater appreciation for how he quickly and in plain speaking handled any extraneous spamming of his thread starters.
