Your question has several dimensions (I won't cover all of them). Here is what I think.
The best way to get shear stability (in multi-grade)is to use oil containing the best VI base oil and use less VII. Oils have improved quite a bit in the last several years so it's less of an issue especially in the grades your talking about. (Think about a 0W40, a 5W50, or a 10W60!)
Then again it depends how long OCI and we are asking more of our oils in this regard.
So I hunt for the best base. I don't mean to jump on the bandwagon but PP (Grp III Shells VHVI base?) and their YB (likely GrpII+) are current top on my list. But I use others also like Quaker State Synthetic, MC 5W20 and SynPower based on price, also I can't push OCI out.
When I blend I expect to get less than absolute best performance from the add pack. So if you're looking for longer OCI I would generally avoid. Blending same brand probably has least risk (but not guaranteed).
So your question is a complex one with unknowns and I believe on this basis alone the risk out ways the reward.
