- Messages
- 114
- Location
- Colorado Springs
Hi, it has been said that syn will shear less then dino oils under load(basic Redline positon and BOSISTHEOILGUY has stated it in a post also). This less shearing, for lack of a better term, I will call it 'dynamic shearing' is when the VIIs align themselves under load and recoil back under less load. Since most agree a syn, like Mobil1 10W-30, has less VII, its 'dynamic shear' should be less the a typical dino oil.
So this seems to justify somewhat the use of sys with all things else being equal and load a consideration. Of course, this presumes that the shearing under discussion really affects wear and is not just some measurable artifact but of little real world interst other than marketing copy by syn oil producers.
What do you guys think? Is this some point to consider? I don't usually hear this point in the syn vs dino wars. It if is something to consider, it seems to be an attribute that only a syn can offer since it has less VIIs.
Thanks
BTW, Redline web site says that a dino 10w-30 oil will shear back to a 10 under load and has a chart showing the shearing under increasing loads. Of course, Redline does well. I assume any other low VII syn like Mobil1 10W-30 would be similar. However, wide range syns like 0W-40 might be a different story.
[ September 03, 2003, 03:30 AM: Message edited by: Fillherup ]
