View inside of a furnace:
Owen Lucas
$100 Site Donor 2023
This company (Logika Technologies) has a YouTube channel showing off what their specialized cameras can do. These particular videos are from inside a furnace.
There is some serious engineering involved into building these cameras. It appears the camera itself does not go into the furnace but a borescope type optical probe that is liquid cooled internally and externally as well. The lens must be made out of some special material, maybe ceramic that can maintain its shape and clarity at these temps.
https://www.youtube.com/watch?v=Ya5Xy5NgvhA
https://www.youtube.com/watch?v=FKjkkDB4nXg
https://www.youtube.com/watch?v=Ij0SbktddT0
https://www.youtube.com/@logikatechnologies/videos
Pushing the boundaries of material & there must be applications where this may be needed. Very "cool" to see inside the furnace!
That is neat. Coming up with automotive applications is going to be a fun mental exercise. Back in the 80s, properly setting the timing on a GM or Ford automotive diesel involved removing the #1 glow plug and installing a dummy plug with a glass center. An optical sensor was attached to "see" the combustion flash and the tool reconciled this with a crank position probe to make a timing measurement. Without the optical sensor attached one could see the orange diesel combustion flash. Gunson in the UK makes a spark plug for seeing the color of combustion in a gas engine. It might be fun to play with one on a carbureted engine. A lot cheaper than a 5 gas analyzer. Setting the Logica up to monitor while driving has possibilities. Just something to ponder before falling asleep.
Here's a view from the bottom of the launchpad with a SpaceX Rocket launching above. I wonder if the same furnace camera tech was used?
Here's a vid I took of low load coal combustion...see the coal emerge from the brner, then get hot enough to ignite.
Wow! Do you work at a power plant? I presume this is pulverized coal not pebble sized chunks?
I made parts for a Japanese company that did the same thing as an apprentice. The engineer they sent to test it smoked 2 packs of cigarettes in the 3 hours he was at our shop, but my parts were water tight! 😅 That camera assembly subsequently went to the BOF at the mill… never did get to see the actual camera. That was a fun project though, tight tolerances AND good surface finishes were a must!
