Video: Lexus LFA oil change
Originally Posted By: hypervish
Originally Posted By: Artem
I'd gladly do oil changes the PROPER I mean, the LFA way if I had a car worth the treatment, say a Brand New BMW M3 for example. That V8 spinning to 8,400rpm would deserve such pampering. The wife's Scion tC... eh, not so much, even though the oil is super cheap for me, having bought it during Kmart's clearance sales.
I found a flaw in their oil change... They did the drain n fill AND THEN changed the old oil filters. I would have put on NEW oil filter and NEW oil, then idle for X amount of time and then change the oil and oil filters again like they did.
who's with me on this?
But, then you'll cause more wear. Because the filter will be dry for two start up's, rather than just one start up.
Who's to say I will spin on dry filters? I'm one of the few on here who feels there's noticeable different in engine noise / oil pressure after an oil change when the oil filter is primed with oil vs completely dry.
I ALWAYS prime my oil filters on ALL the cars I service. My 98 Camry V6 had the oil filter mounted in the exact same position as the LFA. I'd still prime it by filling it up with oil to the brim and then wait a few minutes to while the oil soaks up into the filter media. Spinning it on afterward would result in no oil spilled but the engine noise would be decreased and the oil pressure light would go off sooner vs spinning on a dry oil filter.
When I used to change the oil but leave the filter on, the oil pressure light would go off almost instantly upon startup and there would be practically no valvetrain chatter, showing that a primed oil filter DOES help with dry start.
Having said that, if that was my LFA and I was doing the double oil change, I'd change the oil filter during the initial drain as TWO (2) oil filters could be holding a good half a quart of used oil.
Originally Posted By: gonefishing
Found this post on a Lexus board: http://www.clublexus.com/forums/lfa-model/655485-first-oil-change-in-an-lfa.html
Looks like lunaC42 is the owner of the car in the video. $550 for the oil change.
Considering the cost of all that Mobil 1 5w50 (how much oil does the LFA hold anyway?) plus the oil filters plus any other parts used that we don't know about, the cost isn't that high, considering how much time was spent during the oil change and the amount of technicians that were seen running around the car.
Good point, but who's to say they are going to prefill the filters and let them soak in the oil, so as to avoid any oil spilling.
The Camry V6 oil filter is not mounted in the same place. I have the same engine, and I assure you it is not in the same location.
$550 for that amount of work seems pretty reasonable.
NFW would I touch a motor like that myself while it was under warranty. Make the dealer do everything, this way if it blows up, its their problem.
Originally Posted By: glock19
I'd be surprised to hear of an LFA owner that does their own oil changes.
I wouldn't trust a dealer to do changes on my F-150. Why would I trust one to do it on an LFA?
Stand beside a car like that while they work on it.
Big mistake to leave a car like that to have an oil change while you sit in the waiting room.
Personally, I'd bone up on how to do it properly myself the second I drove the car home, and do it when it needs to be done.
Too much stress trusting others with your baby of any sort.
