EE is basically saying if you have enough protection, then you don't need any more. But here's the clincher ... how do you know you always have enough MOFT protection in all driving conditions? Only way to really know is do your own test program or trust the "recommended" viscosity call-out in the OM. And as shown here many times, the same exact engines used in other countries show a whole range of acceptable viscosity above the lowest "recommended" called out. In fact, some of those OMs show that anything from 0W-20 to 20W-50 could be used depending on ambient temperatures. So engines are not "designed for" any specific viscosity, expect those that spec 0W-8 and 0W-16 as has been discussed in many threads. Instead, engines are designed to be able to use a whole range of oil viscosity.
Many studies show that more viscosity results in less wear overall, more so in some engine components than others. Most of the wear studies show that as the HTHS starts going below 2.5-2.6 cP, the wear starts increasing more in certain engine components. Yes, in most cases the "recommended" viscosity is going to work for everyday street driving.
@OVERKILL mentioned "
xW-20 and an HTHS of 2.6 cP is right on the bottom of where "traditional" designs still work properly", which is why engines had to start using special design features to start using oils below xW-20. But is xW-20 always going to give the same wear protection as a thicker oil? I say not always, and the example of Ford now deciding to finally go up from 5W-20 to 5W-30 in the Coyote is a good example. They only did that for one reason, that's to give more engine protection. The Coyote always got 5W-30 specified in other non-CAFE countries, but Ford decided to go with 5W-20 in the USA.
My take is if the engine specs xW-20 or less, go up a grade to add some more wear protection headroom. If the vehicle specs a xW-30 the only time you might go up a grade if it's going to be used for track use, or some other very heavy use conditions.
Here's what happens on the Stribeck Curve if you go up in viscosity. The MOFT is increased in both mixed and hydrodynamic lubrication, and that means more parts separation and less wear.. The friction in mixed lubrication could actually go down, which helps offset any increase in oil shearing friction in fully hydrodynamic lubrication. What EE didn't really clarify very well is that going up in viscosity adds wear protection because it results in more MOFT between moving parts. That's the whole role of viscosity, to keep parts from rubbing and wearing. Nothing bad happens when there is some added MOFT, regardless if it slightly reduces the fuel economy.
