I finally got my dry loop dsl from dsl extreme hooked up.the dsl light is steady green but the internet light is red.I already tried cycling modem/router but it still persists.Anyone know why it's red instead of green?
If you cannot get a login prompt call DSL Extreme. The network side (central office) of the order needs to be completed. It should be quick; the hard part is often getting a steady green light due to poor line (wire) conditions.
The red light finally went out.Now there's no light on the internet display.The dsl light is on and steady.So do i need to get authentication from extreme? I did have this setup working good at my previous place,which was an apt.
1 more thing- if you are still not getting a login prompt for your account the router may need to be reset; usually a small button you hold down with a pen while powering up. Release it when lights stop flashing. Sometimes you are sent equipment that is used. The login prompt is usually a onetime thing.
Called dsl extreme and they helped me with the router setup.I think i had to log in first,and they also did things on their end.All good now, thanks to all again!!!!
