Varnish/stains
Georgia
I have noticed on ever Honda engine I have owned you can see a varnish build up/stains, nothing to the order of sludge mind you however I see these pictures floating around this site that look like new cast iron/aluminum with oodles of miles and long OCI's. I wonder what causes engines to either stay clean, or have the varnish look ? Also I'm not worried at all about it, as from reading, and my past experience Honda's are really easy on oil, Dino, synthetic blend, or synthetic ( I tend to prefer the synthetic blends and run manufacture severe service OCI at 7500). Any opinions on this ?
Clint
It will not not cause any issues.
I quality synthetic and a good OCI has kept my cars while I had them in clean condition.
been running formula shell 5W20/5W30 (depending on which one is on sale) on dad's 7th gen civic. No varnish can be seen the during last summer when I took the valve cover off to replace all the gaskets and spark plug tube seals.
Q.
I recently had the valve cover off a 1990 Miata with 120k miles (helping a friend change the timing belt, yes you have to remove the valve cover to get to the timing belt!). Very light varnish was evident, but nothing to worry about. I know that he has run conventional oil with 3k mile OCIs forever in the thing. Of course, 1990s vintage conventional motor oil was made to a much lower standard than today's conventional oils.
All in all it didn't look like anything to be even mildly concerned about though.
Here is a Honda 3.5l V6 in a Vue.
80k on the motor and mostly follows the OLM for OCI.
5w-20 only and ever used in this engine.
Take care, Bill
