No.Will ANY diesel additive work to reduce the carbon?
Volvo D3-200 (Marine)
Boat is used lightly - was told the engine turbo needs to be used HARD to keep turbo from carbon-ing up
Fuel doesn't really reach the turbo.... so the turbo needs to be driven balls to the wall to keep the vanes from stickingVolvo D3-200 (Marine)
Boat is used lightly - was told the engine turbo needs to be used HARD to keep turbo from carbon-ing up - Will ANY diesel additive work to reduce the carbon?
Fuel is direct injected in diesel engines. running the engine hard sometimes allows the vanes clean the full path of the vanes movement. Kinda like a windshield wiper clears the water off of their travel area.Volvo D3-200 (Marine)
Yes. but you're looking at a specific kind.
I'm sure they do. Right up until they're stuck I guess.Engineering Explained just put out a video where Borg Warner said some diesel soot provides lubrication to the vanes.
Not everything Justin beiber the Engineer says is true.Engineering Explained just put out a video where Borg Warner said some diesel soot provides lubrication to the vanes.
He was quoting BorgWarner reps as they build the turbos for the 911.Not everything Justin beiber the Engineer says is true.
Marketing reps aren't always the technical type. Soot as a lubricant? It's more of an abrasive.He was quoting BorgWarner reps as they build the turbos for the 911.
Which is why is prefaced it with "a little, just a little".Marketing reps aren't always the technical type. Soot as a lubricant? It's more of an abrasive.
Just like his Michelin Cross Climate 2 video, it was just a paid marketing video by Michelin.
These...Volvo D3-200 (Marine)
