I've seen this on *NEW* engines just after shut down. Completely normal.Is it a somewhat trusted indicator of oil burning if these vapor fumes are visible when a car's engine is hot and just turned off, or is it normal in most cars over 200k miles?
Normal. My car has done this since new and doesn't burn a drop of oil. Oil get very hot when the engine is running and even without water condensation can vaporize.Is it a somewhat trusted indicator of oil burning if these vapor fumes are visible when a car's engine is hot and just turned off, or is it normal in most cars over 200k miles?
To add to this remember that the inside of an engine is a harsh place, if it's OHC there's camshafts spinning at thousands of RPM flinging oil all over the place, the crankshaft and connecting rods along with piston oil squirters... Timing chains... Combined with the heat its totally expected that all that oil being flung around vaporizes.Normal. My car has done this since new and doesn't burn a drop of oil. Oil get very hot when the engine is running and even without water condensation can vaporize.
Yeah that too. If one were to open the oil cap on a DOHC timing chain engine while it were running they'd be sprayed with oil.To add to this remember that the inside of an engine is a harsh place, if it's OHC there's camshafts spinning at thousands of RPM flinging oil all over the place, the crankshaft and connecting rods along with piston oil squirters... Timing chains... Combined with the heat its totally expected that all that oil being flung around vaporizes.
You are not seeing oil vaporize. You are seeing moisture leaving the oil. Even when running flash tests at which point the oil vaporizes enough only to flash, you don’t see anything coming off the apparatus. If you are chasing fire point or auto ignition you will be at a level where the oil will smoke. These are temperatures you will never see in an engine.Normal. My car has done this since new and doesn't burn a drop of oil. Oil get very hot when the engine is running and even without water condensation can vaporize.
Clean or replace your PCV valve and re-assess.Thanks for all replies. That makes me feel a little better.
