Has anyone tried this oil in their mowers or snowblowers? I’m curious because it’s high in zinc and phosphorus. Since emissions don’t really exist for OPE, this stuff should be really good for small engines
I run the 20W-50 flavor in my MG for the zinc, but it does seem a little overkill for OPE. Seems to me that stuff isn't all that cheap compared to HDEO.
I believe the meaning of this is that a mower will fall apart, wheels fall off and the deck with rust through long before the engine will wear out (in a typical residential use case). Therefore, why spend the extra dollars on special oil?I always find the mindset that a particular oil is too-good for OPE interesting. If that were true then the pros who log 1000+ hours a year with 50hr oil changes wouldn't wear out engines every couple years.
