VALVOLINE VO-39 CUT OPEN
In the shop
This was off friends 2019 KIA FORTE that had Valvoline blend 5w30 for 4,200k on it. Sees 60/40 city-highway driving as friend has 3 jobs and is always on road. Looks good. Put on a Prime Guard filter he supplied and some Mobil Super 5000 10w30 from Rural King.
I've been trying to figure out who is making Valvoline quick lube, indie shop OFs. Think I got it. Looks like a Prime Guard filter. So either PG or whoever makes these OFs for PG. As for coo, coil spring likely China. Linked is equivalent PG POF 4459 by 53', baseplate design similarity including #20, and other features.
https://bobistheoilguy.com/forums/threads/prime-guard-pof-4459-cut-open.276391/
'Looks' good.
Thanks for c&p.
Adding to my last, I said made by "either PG or whoever makes these OFs for PG". I'll say most likely the latter choice, because more recently saw PGs with Champ Labs construction.
Thanks, does your Filter look strong, ? GOOD showing: fairly good filtering & integrity?. ( obviously you cannot nod Lab Works..interestingly my new GARAGE , JUST used VALVOLINE VO58( Bulk pak) Filter,& VALVO5w—30 *SYNTHETIC, IN MY 2007 GMC CANYON, 4 CYL@144,000 miles… ** normal MOB1 SUNTHETIC, & WIX(FILTER NAPA GOLD), or BOSS Purolator….!, ( Garages VALVOLINE FILTER VO58 appears to be less robust, BARELY 3-6 month use?? Thanks.
