Hi all.
for my next oilchange. i am considering one of theese to oil. The Valvoline synpower 5w30 FE VS the Total quartz 9000 future. based on the technical datasheet. would would you choose? the engine is a mazda 1.8 mzr. Now i am using the valvoline. but if the other one seems better i want to try that one.
SynPower FE motor oil
SAE Viscosity Grade 5w30
approvals/recommendations
API: SL/CF
ACEA A5/B5-10
ACEA A1/B1-10
Renault RN0700
Ford M2C913-C approved
Ford M2C913 A & B
Recommended for use where
Fiat 9.55535.G1 is specified.
Data
Viscosity, mm2/s @ 100 ºC. ASTM D-445 : 9.8
Viscosity, mm2/s @ 40 ºC. ASTM D-445 : 54
Viscosity Index ASTM D-2270 : 169
Viscosity, mPa.s –30ºC. ASTM D-5293 :
TBN, mg KOH/g ASTM D-2896 : 10.1
Pour Point, ºC ASTM D-5950 : -45
Specific Gravity @ 15.6°C. ASTM D-4052 : 0.852
Flash Point, COC, ºC. ASTM D-92 : 222
Total quartz future 9000
approvals
ACEA: A5 / B5
API: SL / CF
WSSM2C 913 B tekniske krav
Ford WSSM2C 913 C motor (A5/B5)
QUARTZ 9000 FUTURE SAE 5w30
Specific Gravity, 15 °C Kg/m³ 853
Viscosity, 40 °C mm2
/s 57
Viscosity, 100 °C mm2
/s 9,9
Viscosity Index --- 160
Flash Point °C 224
Pour Point °C -36
the total oils should be identical to the one mazda sells as dexelia 5w30.
thanks
Søren
API: SL/CF
ACEA A5/B5-10
ACEA A1/B1-10
Renault RN0700
Ford M2C913 A & B
Data
approvals
ACEA: A5 / B5
API: SL / CF
/s 57
/s 9,9
Flash Point °C 224
Pour Point °C -36
thanks
Søren
