Valvoline Restore and Protect
There were some posts about gtl content in the restore and protect . 0w20 having the most and 5w30 30-60 % do a search
I did and it’s not looking good. I believe these are constantly changing.
The good thing with VRP is it's not the base oil that is doing the cleaning. So if it dropped from GTL to III I wouldn't be concerned.
If you're looking for certainty right now - Amsoil, HPL are most likely not going to drop base oil type.
Marketing. Group "III+" is not officially recognized by API. It's a made up term.
Dismissing “Group III+” as marketing is incorrect.
You cannot stamp “Group III+” on a retail jug.
API EOLCS, SAE J300, and ATIEL force finished-oil labels to say “Full Synthetic” or simply “Group III.”
Shell’s own technical literature lists PurePlus/GTL as API Group III for the simple reason that API 1509 contains no “III+” category.
Zero consumer-marketing upside.
The term is B2B engineering language, not ad-agency terminology.
It was coined by refiners and additive companies (Infineum, Lubrizol, Oronite) for base-oil interchange guidelines and technical data sheets.
When API 1509 defined Group III it set an open-ended floor: VI ≥ 120.
Conventional hydrocracked Group III landed at roughly 120–128 VI.
Commercial GTL delivered 135–145+ VI with near-zero sulfur/aromatics, and much lower Noack.
The industry needed a practical label for that step-change.
“Group III+” is that label.
I don't need to do anything you started by saying
"GTL is legitimately a cut above standard hyrocracked Group III"
I said "Not necessarily and / or by a lot that's makes much difference"
You define why its a cut above.
Seems to me like restore and protect 5w-30 can put down some very impressive results at 10K OCI with just that 30-60 % GTL. Here is a UOA at 10K on a 4Runner with Iron 3 and aluminum 3.
Fair enough.
GTL sits objectively above standard hydrocracked Group III for these reasons:
GTL offers a 15–20+ point higher Viscosity Index (135–145+ vs 120–128).
Higher natural VI means less shear-prone VII is needed to hit 0W-16 / 0W-20 targets, which improves shear stability and reduces deposits.
It also delivers 20-25% lower Noack at equivalent CCS viscosity.
Because it is made from pure methane, it has near-zero sulfur and aromatics and therefore better inherent oxidative stability.
Those differences are large enough that formulators treat the two stocks as non-interchangeable in tight low-viscosity applications.
Now what's the threshold of “a lot” or “makes much difference”?
In a fully formulated PCMO the advantage is for the formulator to reduce costs in less additives such as PP,VII perhaps AO. A GTL shows better in a low formulated oil like a Turbine oil.
I have not seen specs that show a 15-20 point VI improvement.
Love to see that spec sheet.
I have not seen a Novak improvement of 20% either but have not really paid much attention.
