Valvoline Restore and Protect
Except it’s $4/qt at AutoZone. So about half the cost.
VRP is $7.2 per Quart at WM in the 5 Qt jugs. And, the performance is what matters. An oil change savings of $16 every few months is not a big deal. You want the better performing oil. Saving money here and potentially having worse long-term ownership results isn't worth it. Cheap insurance for a well running machine. Save money elsewhere rather than potentially developing oil consumption and spending the money on top off oil anyway. This is the way.
I'm getting impressed with this oil. Started using it last year in my 97 Volvo 960 which has a 24 valve, 3.0 liter inline six. It has 153K miles on it and was fed Mobil 1 for at least the last twenty years. It's a dedicated highway car, which means all highway with the cruise control set ninety five plus percent of the time at 55-65 mph. Last year the first fill with R&P the oil was very dirty within 1,000 miles or so, and got darker as the miles went on. Plus I had to add an additional one and a half quarts last year. Did my once a year oil change at around 4,000 miles on the first fill and refilled with R&P. I have around 1,200 miles on it and the oil only has a slight discoloration. Highway gas mileage has gone up also about one to one and half mpg. The best part is I haven't had to add any oil so far on this second fill.
Got Valvoline Restore and Protect 10W-40 from Auto Zone today. Using it in the Kawasaki FS691V. Will let everyone know how it works in time.
Saw these photos on another forum. AU VRP. 6k miles.
"Thought I'd share my anecdotal review of Valvoline R&P.
TL;DR: Very impressed so far — ~10,000 km on R&P has noticeably cleaned varnish off the rocker cover (no oil analysis, sorry). Results appear to match others’ reports and the marketing.
Background
Vehicle: 2011 Honda Accord Euro (CU2) 2.4L, 6-speed auto, 202,000ish KMs, full dealer service history prior to me owning it"
BEFORE:
AFTER 6k miles:
Background
BEFORE:
AFTER 6k miles:
Thanks for sharing here. I assume 10W-40 in Oz?
Background
BEFORE:
AFTER 6k miles:
Excellent results! And as we know, the valve cover is only incidentally oiled (splash) and is cooler, which is why it is prone to deposits, so this also I think shows that VRP doesn't need heat to work.
I think the valve cover is probably going to be pretty hot during engine operation.
The valve cover should get as much hot as the oil temp., so at least 212°F. But it may get hotter because doesn't have any type of cooling.
Also, valve cover paint sprays are usually rated at 500°F and over. However, I don't think the valve cover would see any temps over 250°-300°F.
Over in the UK they advertise 99% Deposit Removal and 78% Sludge removal. I would say that's why people are seeing both. If I'm reading in between the lines it sounds like it works best in a very hot environment.
Next oil change I’ll use 5W30 in my wife’s 19 Pilot with 95K. It’s had Amsoil SS 0W20 and for the last 3 oil changes SS 0W30. OLM changes till 15%, 5500-7500 miles. VCM is disabled. Giving that SS is now 14.00 a qrt with preferred pricing it’s time to step away.
Amsoil SS won't prevent Piston Rings from carbon buildup anyways, it will slow it down better than your average oil, but not stop it and differently not reverse it.
