- Joined
- Feb 4, 2023
- Messages
- 189
engine braking should help clean up the rings quickerGo for a 30 min highway drive and drop 1 or 2 gears on the trans.......rev it higher while cruising
Both are goodengine braking should help clean up the rings quicker
The oil control rings are the only place in my HEMI I can think of that the material HPL liberated came from (whole life prior on Mobil 1 Extended Protection 0W-20). This is consistent with KnappAttack stating that it provided the same effect (got rid of the oil consumption problem) as Restore and Protect.Another option is Mobil 1 ESP oils...but like HPL, these both have a different cleaning claim than Valvoline Restore and Protect. Neither claim to clean and free up oil control rings. So neither may provide the desired results.
really? it does? dint know it has such benefits.how often should i do that? its better from higher revs or just in town slow speed?engine braking should help clean up the rings quicker
and i cant have any of them,now that i need them..The oil control rings are the only place in my HEMI I can think of that the material HPL liberated came from (whole life prior on Mobil 1 Extended Protection 0W-20). This is consistent with KnappAttack stating that it provided the same effect (got rid of the oil consumption problem) as Valvoline Restore and Protect.
Hit the highway......that will get the oil good and hot with a decent load on the engine and rings.really? it does? dint know it has such benefits.how often should i do that? its better from higher revs or just in town slow speed?
Most of the video was just a nothing burger. More of what we already knew watching the original tear down video.The Motor Oil Greek just posted a new video on Valvoline Restore and Protect.
Restore & Protect vs Deposits (500,000 Mile Engine Tear Down Reveals All)
What I wonder is what the temp has to be and for how long? My Impreza, especially during the winter during my commute might not get to 180F. I can if I put it in faux manual mode and drive in 2nd and 3rd gear during my 5 miles 15 minute commute. The summer is obviously different but still not hitting 200+.Important to note what the Valvoline Dr. Warholic has to say about the oil coming up to a sustained running temp in order for Valvoline Restore and Protect to provide the best results . My average drive on Valvoline Restore and Protect is about 30 minutes of sustained driving with part of that on an Intersate with a couple of hard pulls thrown in then abruptly letting my foot off of the gas pedal . I would imagine short trippers would have less desirable results with Valvoline Restore and Protect if their oil is not brought up to running temps often enough . Lastly , due to a dirty running Hyundai 2.4L GDI engine my OCI’s are 3,800 miles to 4,000 miles / 6 months max as this engine thrashes oil like it invented the term. Others with better engines would be served better to run Valvoline Restore and Protect 4,000 to 5,000 mile / 6 month OCI’s. Short trippers need to get out for a weekly sustained drive getting that Valvoline Restore and Protect up to temp for a period of time if you want the max cleaning benifit .
But how?engine braking should help clean up the rings quicker
The idea is that the vacuum created in the cylinders with the throttle blade closed will pull "out" on the rings. This can also draw oil by the rings however, leading to a bit of consumption.But how?
I always downshift and I can tell you there is some issue with my oil rings. I have about 1.5 qt oil consumed for 5K miles.
White Monster? Haven't we had the talk about additives yet?Ready to run in the A3. Also next change for the Focus and of course a White Monster.
Why the Motor Oil Geek calls (in the UOA) Silicon, a Silicone and says it's from RTV/sealants.The Motor Oil Greek just posted a new video on Valvoline Restore and Protect.
Will 16 ounces cause much dilution? Does the carbonation help get into the nooks/crannies?Ready to run in the A3. Also next change for the Focus and of course a White Monster.
Minuscthe white monster. Used to drink the green one long time ago. Don't do itReady to run in the A3. Also next change for the Focus and of course a White Monster.
I'm close in miles, and I had the same thought. Good time for a good cleaning. Running 4 OCIs and will then re-assess.I am at 257k miles now, so I would imagine a good cleaning wouldn't be a terrible idea.
different situations so different answers. This time it's from putting the engines back together. They were completely torn down. The other time, it was a different situation. These engines have 500,000 miles. They aren't breaking in...Why the Motor Oil Geek calls (in the UOA) Silicon, a Silicone and says it's from RTV/sealants.
But in previous videos has said Silicon is from break-in pistons rings and cylinder walls.
Something not shown in the Valvoline tear down was the bottom of the piston clean-up ... that was pretty impressive.Most of the video was just a nothing burger. More of what we already knew watching the original tear down video.
The biggest NON-nothing burger was the test results showing reduced fuel contamination in the oil. All attributed to Valvoline Restore and Protect.Most of the video was just a nothing burger. More of what we already knew watching the original tear down video.
