Valvoline Restore and Protect 2AZ-FE Observations & Questions
I've been using Valvoline Restore and Protect 5W-30 in my Toyota with the 2AZ-FE and I'm almost 3000 miles into the second interval. I changed the first at 3000 miles and I'm questioning whether to change again at 3000 miles or go to 4000. The reason for thinking it can go to 4000 miles is it still looks fresh. The first round, it got dark quickly and 3000 miles looked dark whether I checked it cold or warm. This round, it is light brown when cold and golden yellow when I check it warm.
That it looks cleaner after the same miles is just one observation. I switched to this Valvoline when I saw the first Oil Geek video about it. It had been consuming 1/2 quart of STP 5W-30 synthetic every 800 miles and had some rattle on cold starts. The cold start rattle stopped immediately with the Valvoline. Right before I made the switch, I checked compression, fully warmed up, and got 180 psi on each cylinder and that's exactly spec. About a month ago, I checked compression again, fully warmed up, and got 200 psi. That was hard to believe so I did each cylinder twice and it repeated.
Another observation is the improvement in idle. That engine would visibly shake at idle and I could see it in the battery hold down, wiper arms, hoses. Now, I no longer see the vibrations. I even tried to measure vibration for a before and after, but all I could get with a pulse sensor was that I get even pulses out of the dipstick tube at 25Hz at idle. The dipstick itself is another observation. It wasn't varnished up before, but it is sparkly shiny now. Looking in the oil fill hole and I really haven't seen anything different.
The final observation is the consumption which is really why I switched. 1/2 quart in 800 miles before the Valvoline and 6000 miles later, that has improved to 1/2 quart in 1400 miles. I check it before every cold start and if I go into the grocery store or anywhere it will sit for 10 minutes. This seems to be improving. The first interval I saw it improve to 1/2 quart in 1000 miles. I'd like to see it just stop but I'll take a 43% improvement.
Almost forgot, my driving is mixed highway and country roads some city. On very long trips before the Valvoline I got 35MPG, AC blasting, 70 MPH. That will be hard to beat, but my next long trip will be an opportunity to see. And I'm at 90,000 miles on the odometer.
If VR&P has made that much of a difference then a Berryman’s piston soak will likely get you to near 100%.
Do I have the time to let it soak? I really should consider it since I've read enough good results. Thanks.
Just for fun, here's a screenshot of the recent pulse sensor in the dipstick tube. She's running like butter.
I have the same engine and using 5W30, it does feels smoother for sure. I am changing it at every 3K to see if it helps with the oil consumption.
How much does yours burn?
The owners manual even has something about oil consumption and suggests that driving it hard will burn more. If I remember right, I think Toyota says 1 quart in 1000 is normal. That blows my mind.
I have rebuilt a few 2AZ-FE engines, a big issue that I saw with 2AZ-FE was that the oil capacity was listed at 4.0 quart with an oil filter...
my 1zzfe was updated (03+ Celica and 05+ Corolla) to 4.4 quarts with an oil filter (I run 4.5 quarts)
In the Camry:
2002-06 2.4L 2AZ-FE engine was 4.0 quarts with oil filter
2007-09 2.4L 2AZ-FE engine was 4.5 quarts with oil filter
I would highly recommend that people run 4.5 quarts in all 2AZ-FE engines, and because they can easily get carbon build up in their rings, also run XW30 weight oil instead of the XW20 weight used in the 07-09 2AZ-FE engines.
This engine is not easy on oil, so use high quality synthetics, when taken care of, these engines can easily get 35 mpg, even better then Corollas from that era.
I'd probably push it to 4-5k with VRP. Your results are consistent with the majority of VRP users.
