Valvoline NextGen recycled oil
Originally Posted By: dparm
Originally Posted By: addyguy
Suprised Valvoline is doing this - re-refined oil doesn't have much of a market in the US.
Sure it does, especially since people are trying to be more green.
Green is for yuppies who feel guilty about their mass consumption!!! With what is happening to the economy and loss of the value of the dollar and the impending growth of government and taxes . The rerefined oil will be used if the price is less. I have no problem with a high quality rerefined oil.
Just like recycled soda pop cans: it takes less energy to recycle metals and lubricants esp. when the initial cost for raw materials is sky high in terms of pricing.
I have absolutely no issues running re-refined motor oils (safety-kleen being one of them).
Q.
Originally Posted By: A_Harman
One interesting question about the oil itself occurs to me: Will re-refined oil have better resistance to shear, given that it has already been run in an engine? For example, will a formerly 40-weight that has sheared to 30 be re-refined as a 30, and therefore be shear-stable?
Of course someone more knowledgeable than me will correct me, but I doubt it. The fractioning process at a refinery uses heat to crack the hydrocarbons in crude oil down to a length that the refiner wants for a certain product. The same thing is going on, in a much cruder fashion, in our engines due to heat and pressure. A 40 weight base oil that shears down to a 30 weight I am pretty sure can continue to shear down to a 20 weight and thinner.
Originally Posted By: 77GrandPrix
I don't see anything about this on Valvoline's web site or with a Google search.
I would guess that the OP is probably in a test market area, with nationwide roll out due later, in a year or more maybe?
I'd think that after the re-refining process, VIIs would be added so it can shear down all over again... The used oil is no doubt going to be a mix of different weights & brands, I'd reason the reprocessed oil would get a add pack to create the new desired weight...
Seen stuff like this before. Back in the late 80's in Canada, a grocery chain here sold their "President's Choice Green" re-refined oil. Their producer at the time was Esso. There may have also been another small label that sold one too. The President's Choice Green had no issues as far as I recalled, but was probably dropped due to misperceptions about it that caused people to stay away from it.
Extending the thought even further: Since the re-refined oil would be a blend of all kinds of base stocks, they could call it a synthetic blend, and charge more than for traditional dino. That follows the first rule of green-product marketing: Provide an inferior product, but charge more for it.
Originally Posted By: Mark72
When Valvoline comes out with this "green" oil, will that be all that is available in the white bottle?
Hey, wouldn't it then be "VGB"???
Seriously though, if Castrol GTX is already recycled oil as someone above stated, is the Castrol we buy at Walmart or Auto Zone recycled? Or, are the companies going to provide two options. Original or green?
I don't see them tampering with their established brand-loyal following. By keeping the re-refined oil as a separate product line they open up a new "green-oriented" customer market.
i wounder how all the different bases will mix? in an oil change shop waste container there will be everything under the sun from synthetic to wolfs head to atf and gear oil... how can they make a decent oil out of that?
The same way they make all those products out of the exact same crude oil...
Inferior in what way?
