Originally Posted By: defektes
Originally Posted By: mopar_monkey
Originally Posted By: Vizzy
It's FRAM striking again.
well that was my concern when i bought it, i swore i'd never use fram anything but i've heard good tings about the tough gaurd so i figured what the hay. the only thing that makes me think it's not the filter is that i have great oil pressure, could it give good pressure but not enough volume?
No, you heard good things about the xtended guard
However, there is a possibility that the engine does not like the oil. Not all engines like every oil and it does not mean the oil is bad. I would swap the filter take it back to autozone and exchange it for a different brand or manufacturer. Or if your rich the xtended guard.
My truck was getting normal pressure with the oreilly fram, but 5 seconds of tick on start-up. Now if the noise is there even after the engine is hot then I probably would rule out the filter.
probably true on the extended gaurd, i think i'll just go back to my previous combo, i've never had any issues with wix filters or mobil syn. blend, but now i'm out $20
