Forte-products are held in high regard and only sold to garages/professionals but seeing as their motor-flush is mostly kerosene, I'd buy STP/Valvoline or whatever is cheap and available.
For the piston soak you can use just about any solvent, kerosene or diesel will work. Remove the spark plugs and pour in the solvent, let soak for several hours. It will slowly drain past the rings so you will need to add some every now and then.
It's a good idea to turn the engine by hand when all the solvent has drained (to avoid hydrolock) so the rings will slightly move and some of the dirt will come loose.
Since the dirt will contaminate the oil I would do it in this order:
1) Warm up engine, add motor flush and run it on high idle (about 1500rpm) for 30-45min
2) Drain oil, fill with some cheap oil and proceed to do piston soak.
3) When the soak is done, make sure there is no solvent in the cylinders, install spark plugs and start engine, let it idle for a few minutes and then change the oil and filter.
