Originally Posted by skyactiv
Hopefully it will have titanium. Titanium is one of the better anti-wear additives when an oil hasn't reached operating temperature yet.
I see you've had a sip of Kendal's marketing Kool-Aid.
Titanium has no lubricating properties whatsoever.
Now, titanium nitride is a surface coating that has superior friction-reducing properties when applied to the surface of a solid material. i don't think it can be applied to an oil molecule.
In the last ten years or so, "titanium" has been touted as having all sorts of magical properties, always as a marketing strategy. Everything from being highly wear-resistant, to being harder than diamonds, to being extremely heat-resistant, to having superior insulating properties, to being extremely strong.. It is none of these. What it is, is a fairly lightweight (about the density of aluminum), fairly strong (the common Ti alloys have a UT strength comparable to many steels), and extremely corrosion-resistant.
I worked with titanium for thirty years, machining it, welding it, hot-forming it, super-plastically-forming it, heat-treating it, vacuum-furnace diffusion-brazing it, testing it, looking at it under very high-powered microscopes. I love the stuff, but it is just metal.
"doing my part to dispel the myths"
