Valvoline Extended Protection vs Mobil 1 Extended Performance
witch one of those two would you choose and why, do you think one is better than the other ?
Valvoline Extended Protection isn't extended drain and used oil analysis of it have been a bit disappointing. And it's too expensive for what it is even if the moly is high. I'd take Mobil 1 Extended Performance.
If you're looking for an oil to use in your truck I'd just use Quaker State Full Synthetic, it's d1g3 which is better than the necessary d1g2 and keep pics of receipts. You don't want to go beyond the drain interval in these new trucks. My 2021 and yours track everything including how often the service minder was reset and how often you go beyond the end. tire pressure. Wot events, fuel level, low oil level warning, and battery voltage to name a few get reported through the cellular connection even if you don't pay for it and they can always pull it even right now remotely if they wanted. I wish I could fully deactivate it but I can't.
Both are fine oils but I'd choose Mobil 1 Extended Performance....as Javier stated the Valvoline is not marketed as a extended drain oil.
Man that's a trip!😯
Man that's a trip!😯
I saw that same episode many years ago.
