So I’m borrowing my girlfriends 05 Saturn VUE as my subaru is being worked on (bodywork). Well, I’m tryin got get a good tuneup while I’m borrowing. So as I’m checking stuff, there’s a large 1 gallon jug of valvoline dex/merc blue bottle in the rear. It’s half full. So apparently, someone put it in the car a while back. What harm is this? Auto trans are kinda a mystery to me.
The car does some weird things. When the car is on a negative load. Like between shifts or if i leave it in low, it will make a “grinding” ish noise. But only when cold. Shortly after driving, it’s much quieter. The car shifts ok, maybe a little sluggish.
The car is the Honda equipped 3.5 and Auto. The fluid is dark red. I’m not sure it smells burned, but doesn’t smell right, but I’m also not an expert on Auto.
What should i do? Should i flush it via, cooler, qt at a time? Drain and fill can get very very expensive. I’ve already put a reasonable amount of money into this.
Thank you.
