I am not a dumb man. But sometimes I do dumb things. This is 100% my fault. So here is the plot.
My 2014 Town and Country just turned 100k. So I figured I would do the works. Brakes all around, oil change brake fluid change and transmission fluid change.
Went to Autozone and ordered all the stuff. I was not paying attention and got the Valvoline Dex/Merc. Right now it still has it compatible with my vehicle. And even on Amazon when I put in Valvoline dex/merc it lists it as compatible.
But everything I am reading it says do not mix different fluid types. And I knew I needed the ATF+4.
So I am assuming I am going to have to drain the system a couple times to get the dex/merc out. The question is did I do any damage just by mixing the 2 fluids in the transmission ? I have not driven it. Just started and moved it 4 feet to close the garage door.
Help ! ! ! LOL (At this point I can only laugh, otherwise I would cry)
