This is the tool referred to above. It's about $15. Some techs love it. I personally don't care for it at all.
Actually, for the early years the Honda 2.4 Liter had the exhaust towards the rear, and then for later years the exhaust is towards the front. So be sure you know what side of the engine the air intake is plumbed into, and what side the exhaust connects to. They actually do differ depending on the year.You are totally right about tight valves NOT being noisy... but also NOT transfering heat, properly, to the cylinder head... and then burning-out. A significant issue.
I, for one, don't really like hydraulic valve lash adjusters... because ultimately, they start ticking... and when you have 16 of them, how do you find the one that is ticking? I guess, however, once one starts ticking - replace all of them.... 'cuz they may all start ticking around the same time?
Hydraulic "lifters" are, however, very, very typical for nowadays' cars. I am really surprised that Honda has manual valve adjustment for their '13 Accord. If indeed they do (and it appears so) - then I would guess that the Design is one where they actually, rarely, need adjustment. The next question, then, is are they shim-over-bucket, shim under bucket, replaceable bucket, or simplest - screw-locknut rocker arm? I also note that the intake ones on the EarthDreams (??) Honda are at the firewall, and the exhaust ones are at the front. I would have to guess that the exhaust ones live a harder life.... and one might possibly surmise that the exhaust ones would need to be adjusted more so than the intake ones. If so, fortuitous that the exhausts are at the front.
I'm talking about the EarthDreams (??) Honda Accord, which I think came-in in 2013... and I believe was the same until at least 2017.... mebe 2018. At least I think it was the same. In 2017 when I bought my Mazda6 - I noted that both the Accord of that same year and my Mazda - had direct injection... (without a back-up of port injection).... So I figured that 'cause the Mazda had the intake around the front - it'd be easier to de-coke the intake valves. For the Honda, I figured it would be an engine-out proposition 'cuz the intakes were at the firewall. NOT to say, though, that the Accords are/were suffering any intake valve build-up. I KNOW the Mazda's are not, generally.Actually, for the early years the Honda 2.4 Liter had the exhaust towards the rear, and then for later years the exhaust is towards the front. So be sure you know what side of the engine the air intake is plumbed into, and what side the exhaust connects to. They actually do differ depending on the year.
There are numerous post on the "Honda CR-V forum" about upgrading the battery to a 24F or at least a 35N. The battery tray and cover from a 2013 Odyssey bolts up to a CR-V and provides a larger tray for the larger battery. Advance Auto carries the 24F battery.That's exactly what I am thinking. My battery is 4 years old. The car has no issues starting. I'll just toss the battery on a trickle charger and test the volts tomorrow.
I just put the EP-35 battery on the battery holder. I threw the tray awayThere are numerous post on the "Honda CR-V forum" about upgrading the battery to a 24F or at least a 35N. The battery tray and cover from a 2013 Odyssey bolts up to a CR-V and provides a larger tray for the larger battery. Advance Auto carries the 24F battery.
Some say the way Honda cuts back on charge to reduce load on the alternator to get better MPGs and the way they load it down wears out batteries fast, and the larger batteries hold up longer to that abuse.
I do not know if the Odyssey tray will bolt up to an Accord. If I owned an Accord I would check the Accord forums.
The Honda part number for the Odyssey box tray is 31521-TK8-A00 and Bernardi wants $10.15 for it.
The Honda part number for the Odyssey battery cover is 31531-TK8-A00 and Bernardi wants $12.04 for it.
There are several other online Honda stores and some may charge a little less, but check the shipping charges to see if the over-all total is lower.
On my 2016 CR-V with the K24W Earthdreams the injector actually sprays on the back side of the intake for a brief part of the time that it sprays, and the way the valve is activated is designed to cause the valve to rotate so all of the back of it gets spray on it sometime.I'm talking about the EarthDreams (??) Honda Accord, which I think came-in in 2013... and I believe was the same until at least 2017.... mebe 2018. At least I think it was the same. In 2017 when I bought my Mazda6 - I noted that both the Accord of that same year and my Mazda - had direct injection... (without a back-up of port injection).... So I figured that 'cause the Mazda had the intake around the front - it'd be easier to de-coke the intake valves. For the Honda, I figured it would be an engine-out proposition 'cuz the intakes were at the firewall. NOT to say, though, that the Accords are/were suffering any intake valve build-up. I KNOW the Mazda's are not, generally.
Now I know we are talking about valve adjustments, not de-coking the intakes... My point only was that I thought the Accord's exhausts are around the back-side.
Yeah when I take mine in for any type of service, usually an oil change and their 'complimentary' multi-point inspection, I make it a point to tell them all I have done myself that isn't in their system. Close to 1 yr. ago they did inform me that the battery failed their test, which I didn't doubt at all. It was the OEM that was about 6.5 yrs. old and I could tell by the onboard charge graph it was likely fading. The replacement wasn't cheap, but it's another OEM with quite good long term coverage, so I'll take that over the typical short lived type sold in most auto parts stores.Service department trying to drum up some business is all that is. Typical Honda service interval for valve adjustment is 100k on most of their vehicles, as are the spark plugs. If you press them on this, since yours is a fairly low mileage vehicle, they will likely pivot to "it's due based on age" which is a load of horse manure.
When vehicles come in for recall is an excellent time for the dealer to push services on people. Happens to me every time I have a vehicle in for recall. I don't think I've ever come home from a recall without some paperwork saying I need $3-5k in repairs, despite the fact that I maintain my vehicles religiously. Most items are pure BS and once I had them recommend a new battery when I'd replaced said battery literally a week prior. I'm assuming the service writer tries to sell every older vehicle a battery, because it's clear they didn't look at it, or they would have realized it was brand new.
It is called book time.how can they charge $299 for a procedure that might involve one new valve cover gasket & takes one hour ? (while eating lunch burrito & coffee?)
true cost should be VC gasket & $88.00. Gougefest.
