V 10 ford 6.8 oil loss / pcv issue
Wisconsin
So heard a few members say maybe bad pcv valve can cause excessive oil consumption. Think the valve is on the right valve cover ( without yellow dipstick) there is a larger hose all cracked. Not sure if thats the actual hose.. or just insulation.
I was 30 miles from home when I took pics and need to stand on a cinder block to start pulling hoses off.
Anybody familiar with the system on my 2001 f350 superduty v 10 ?
Just replace the hose. See that catch take with the 6C324 number? Take that to your parts department and they will thank you. But the service number should be YC3Z-6C324-DA. You can get teh valve by itself, but those hoses fall apart and cause all sorts of issues.
  • Like
Reactions: GON
The oil filter adapter on many of the V10's, tends to suddenly leak and deplete the engine's oil. Take a very good look at yours.
With my 5.4 it put a LOT of oil into the coolant when it failed. Like all of it. And quickly. I only noticed because there was a weird emulsified puddle on the ground. I had literally checked the oil 20 miles previous.
Thanks I was going to take it apart. Its easier to just stop at the dealer and buy a new one. Thanks
That looks fine on mine. Zero drips anywhere.
Going to just change oil again as the few quarts of oil that came out looked like death..
