Originally Posted By: 10bears
This is with only 25,000 miles on the car, so this was a botched differential setup by Ford.
I decided that with all those fairly high powered data logging pulls with things this far out, the gear set almost certainly now has a wear pattern on it that will always mean it will be noisy.
I was always told by installers, and gear people/vendors that the above is the case (noisy wear pattern) in as little as 500-1000 miles!!
You should like the 3.73s, more snap/response, but they don't KILL mileage, or force you into the rev limiter at/near the traps/top end (IF you drag race at all) in 4th, like 4.10s or above will.
