Originally Posted By: 10bears
Hey, Jim.
Thanks again for input! I once again went through gear set up including some minor back and forth on pinion shim and side shims several times on latest disassembly/reassembly.
I ended up with a .0345" pinion shim, .276" custom lapped left side carrier shim and .269" right side shim.
From the marking patterns, I came to the conclusion that: Either the first 200 miles put more wear on the gears than I would have expected...
or
The housing is warped or poorly machined...
or
The gears drive and coast patterns are just a tad out of sync...
or
A combo of the above.
In any case, I settled on a perfect drive pattern while coast was a bit towards toe... with a nice classic bullet nose... but a tail I didn't exactly love. I went this route because it appeared that the minimal wear pattern was causing at least some of this. I hoped I was right.
At least drive and/or coast aren't running off heel any more and I ended with almost no offset between drive and coast.
Driving results:
Drive is absolutely silent. Decel at 2 speed ranges was initially somewhat noisy in one, slight in the other.
2nd heat cycle drive saw both ranges reduce noise by half. So I suspect new pattern shifted off first 200 mile wear pattern was the cause. E.g., pattern perimeter was back in some of the unworn black oxide coating.
I have a ton of time in this build, now. But whatever, it's a hobby. I've decided this particular set of FRPP gears either could never have been set up to be silent OR it might not be possible after the first 200 miles wear pattern.
I am encouraged that coast noise is decreasing rapidly instead of going the other (bad) direction.
Current gear oil is Amsoil 75w140. I did install new pinion bearings and races AGAIN during this round of setup tests and patterns. Hence the 3 heat cycles again.
FWIW, not how I would have wanted things to go but looks like I'm going to get an acceptable result.
Gotta put an end to this soon; getting another total hip replacement in about 10 days (right side this time) so I won't be doing any heavy wrenching for a long while. Sounds like a pain in the (bleep), no?
Micke
Heel and toe position is very difficult to control within the narrow range of the backlash adjustment, plus it's based on the machining of the housing as you surmised. If you get a good face/flank pattern, the heel/toe doesn't make too much difference in the setup result. That's what Randy Lyman told me years ago and has held true in the decade since.
In my experience, you are actually lucky that the R&P didn't set after 200 miles. When I worked for Land Rover in the '80s & '90s, they had a big issue one year with noisy diffs on new vehicles. Whoever was setting up diffs at the factory had some form of "cranial rectitis" because many were wildly out of set. Maybe it was the beer machine in the cafeteria (and yes they had one... I saw it). For a while, they had us pull the diffs apart and set them up properly but we found that if the vehicle was delivered and had more than about a hundred miles, they would stay noisy no matter what. If we did it during the PDI period before many miles were put on, we had almost 100 percent success. Problem was, it took an act of God to get them to allow us to do it before the vehicle was delivered and before there was a customer complaint. In the end, they had us replace the pumpkins for warranty. This was my only real experience with this sort of thing, so it may not hold universally true (though people generally say a gear pattern cannot be 100 fixed after it sets) but these Rover diffs were RADICALLY off the correct setup, so that may be why. Off a little might not mean as much. Anyway, glad you got it set up and running quiet. Try not to blow it up on the burnouts, willya? ( : < )
