I sell Yamaha generators used in the ice fishing industry that are run on the eco mode all the time. The owners manual doesn't give a break in procedure, so the customers just start using them normally in the eco mode. Several units have started using oil, enough to make them shut down from low oil after 1 or 2 tanks of fuel. The units have been taken into a service center and tested but were told the units are ok and only have 4% leak down, so manufacturer won't do anything. My question is does leak down have any affect on the condition of the oil sealing rings and second does anybody now of a way to correct the oil consumption with out tear down.
Is anyone else having this trouble with the Yamaha 2000 watt inverter generator
