Just picked up a new DuroMax 9500 dual fuel inverter generator. I read a ton of posts on here for advice on oil and breaking procedures. I went with Rotella T4 10W30. Ran it about 30 minutes and dumped out all the sparkly oil, ran it another 30 with a couple 5 minute intermittent 1,600 watt loads and also toggled the high and low idle speeds through out both runs. Dumped that oil too, still sparkly but not as much. I’ll run it for the next 5 or 6 hours on this oil and start adding more loads but not to exceed 50%. After that I’ll switch to a full synthetic 10w30 or 5w30 and figure which oil I’ll use. I figure at that point maybe good ole supertech full syn will be good. I’ll change it every 50 hours or 6 months after that.
So, Thank You All for the contributions to this site, it is a wealth of knowledge. Much Appreciated!!
