I hear about people working on engine internals and then later ruining bearings because dirt got into the oil pan, BUT, I've always wondered why the filter did not capture the debris.
Now it is my understanding that when the oil is cold, the engine's oil filter bypass can be activated because the oil is still thick. Which means any debris that got into the engine will not be filtered out until it is too late.
Is there some logic to using the thinnest oil you can get your hands on when first starting an engine that has had an overhaul so that the oil is thin enough to prevent the oil filter bypass from opening?
Now, in my personal situation, I just put a new head gasket on my 99 4.0L Jeep. It took extensive cleaning to remove the 20 year old gasket from the block surface. I used many rags to try and prevent debris from entering the lifter galley but I know some got in there. When the engine runs, the oil will drain through the galley and the debris will end up in the oil pan.
My plan: Fill the engine with 5 quarts of M1 0w20 and a new filter. Start the engine and let it run until hot. Drain the hot oil. Refill with the correct 5w30 and a new filter. Done.
I realize removing and cleaning the oil pan is probably the best way to go, maybe I'll end up doing that too, but I still want us to focus on the bold question above. Thanks.
