digitalSniperX1
Good information Doug. I think the clean burning issue is the major issue.
Some do say the eccentric shaft is not propery lubed with 20weight and that 20weight will not develop enough oil pressure at high RPM to protect it and associated gears.
It's interesting to note, the engine burns very little oil when driven normally. When driven agressively, oil consumption as well as exhaust pipe soot increases significantly. I've also noticed less soot in the tailpipe when running the premix.
None of this is scientific of course and I've only been doing it for a short period; so my sample size is very small.
In the long run, I'm expecting to simply run the 5-20 with perhaps 5-30 in the summer and it'll most likely be Pennzoil.
Unless there is a cat converter issue using the premix that I can't tolerate, then I'll probably stop that also...even if recommended by rotary experts here in the US.
Mazda does sell oil for mixing with gasoline in rotary powered cars however I'm not sure they offer it as a supplement for their OMP in a daily driver or if it's just to be used in racing applications. I'll have to look into it and see.
