Technically, there might be some basis for truth in that article but I really don’t know enough to state one way or another. Higher octane fuel does have a slower flame speed, which is really easy to understand if you look at it this way. Higher octane fuel requires a higher ignition temp, which is why it is more resistant to detonation. Since the gas/air charge has to heat more prior to lighting off, it takes just a scoche longer for the ignition wave to propagate. Does it have any meaningful difference in reality? I don’t know.
it’s plausible that the flame propagates faster when under more compression, since the molecules are more tightly packed, suggesting it’s less of a problem in higher compression motors.
I’ll also note that if you take the headers off an engine and watch it run, fuel is still being burned for another 6” outside of the heads, as each exhaust port shoots out blue flame with every exhaust stroke.
