Same filter, same use...no towing or anything other than normal home/work/home trips.
Nothing out of the ordinary. Heading into summer, so maybe a bit warmer vs a bit colder...but I live in a mild climate (VA).
I had some Castrol 5w30K left over from before and my prior UOA on it wasn't great. To see if it is a break in issue, I used that for the current oil. If the numbers come in different than the run of 5w30K before, it should point towards break in vs oil performance.
After that, I am thinking about going to a Dexos D 0w20, probably Mobil 1...and just staying there if it tests well.
