I did not judge or correct anyone's knowledge. I was agreeing with MolaKule about different oil types containing different friction modifiers. I was not instructing him to read his own article, which I linked, but rather indicated that I had done so. I used informal English in stating "Read your article here:," and I see now that the meaning was ambiguous. The word "read" is past tense, pronounced "rɛd," and the initial "I" was (informally) left out. Informative article, by the way.
I also referenced some research from Red Line Oil. In the following graph (sourced from the pdf quoted below), we can see that motor oil (top line, SAE 30 SF) generally has a hig[h]er coefficient of friction than Dexron II ATF (middle line). On the right side of the graph, we see the relationship change.
