I have a Cummins brand generator that is based on a 4 cylinder car engine. The engine uses a spin on Fleet Guard brand filter, model LF3537. I was looking to use a newer synthetic filter on the engine when it comes time to change the oil. https://www.oilfilter-crossreference.com/ lists a whole lot of filters on the cross reference page. It specifically lists Fram PH7317, which has a version in their ultra synthetic line (XG7317). The threads, height, gasket all match fairly closely. The bypaass setting is 13 vs 12, which shouldn't be an issue. The actual outer diameter of the filter is quite a bit different though - the Fleet Guard is roughly 3", whereas the Fram is about 2.68". Any issues with going with the Fram? I wouldn't think so, but wanted to get some feedback / opinions before I commit.
Thanks
Thanks
