Is there a difference between an engine oil filter and an Allison trans spin on filter? Case in point, when I went to the Wix filter site and typed in HP1, the Fram hi-performance filter, one of the avail filters down the list is Wix 51622, which is the Allison trans filter. Also on the Purolator site, pureone.com, and put in HP1, it lists the L39001 filter. The application is for a VW air-cooled engine which has been modified for a full-flow oil filter. For decades one particular shop in So Cal has sold the Fram HP1, stating the use of the standard Fram PH8A could burst as the filter is installed before the oil pressure relief valve, which is there to protect the cooler.
