Originally Posted By: chevrofreak
Originally Posted By: sprintman
If you are not using 40W70 you need to question your manhood
Quite the opposite is true. If you aren't using 0W-5 you need to question your manhood.
Using super thick oils means you're a scared little girl
Lmao, this stuff is getting too funny. I thought the first one was funny, but that's a hilarious comeback.
If you use 20W-50 or thicker, you might be a redneck.
If you use 0W-20 or thinner, you might be a yankee.
In reality, I think a little thicker oil will never do any harm. Manufacturers in America spec lower viscosity oils due to, and ONLY due to the EPA. There's a UOA right now in the UOA section that has a car spec'd for 5W-20, but a 5W-30 oil showed less than half the wear.
You can't argue with people getting 300,000 miles with no leaks or ticking with a 20W-50, but at the same time, people have went that many on 30 and 40 weights, BUT a thicker weight does, naturally, provide a thicker film for better protection. You have to think, even with a 0W-20, when you first crank your engine up, it's going to be thicker than a 20W-50 HOT for 10 - 20 minutes.
UOA's will tell a lot about each specific engine, as all engines won't do best with a 20W-50, I'm sure. I wouldn't put 20W-50 in a 4.6, because it's widely known they actually do have tight tolerances, but other engines may actually do better with a 20W-50 than anything else. A hard working engine does benefit from a thicker oil, while a highway cruiser or especially a short trip only vehicle will be fine, or do better, with a thinner oil.
