Wonder if a 60's Chrysler ballast resistor in the line would work?
We already shot that down!Wonder if a 60's Chrysler ballast resistor in the line would work?
That would not 'split' the voltage...Why not a simple voltage splitter by putting a resister in parallel to the horn?
eBay has knockoff road runner horns.Ok, I sold the horn to a model A owner for $75, so I will buy one of those whinny horse sounding horns.
seems least hassle, and of course horn ohmic value or current draw from 6v must be known to pick right bulb.use a headlight bulb in series, maybe 2
They're not exactly uncommon and expensive either. Suppose 5A running current, BUT is the driver going to lay on the horn all day? Probably not, so the resistor doesn't need a continuous operation/heat (wattage) rating for only a few seconds operation. 50W should be plenty.You'd need some pretty hefty resistors to handle the power dissipation. 100W or more. Those resistors aren't common and they aren't cheap.
12V/5A = 2.4 ohms resistor which is about $6 plus S/H:
https://www.digikey.com/en/products/detail/te-connectivity-passive-product/HSA502R4J/2366308
Then the question becomes how long the horn is realistically going to be activated, since this determines how much heatsinking the resistor needs. I might just hook it up with no heatsinking yet, lay on the horn the longest you think it'd ever be used (10 seconds? Even that seems a long time) and feel the temp of the resistor.
No, I didn't miss the point...and what you posted is the same as what I posted...a voltage divider circuit. In this case, the horn itself is the 'resistor' load...although, not knowing the internals of the horn in question, it could be resistive, capacitive, or inductive or a combination of the three. But being DC current, assuming a pure resistive load should be good enough. So, think of the horn as 1 'resistor' so, you need a second resistor in SERIES to divide the voltage. You can put the second resistor before or after the horn. There will be a voltage drop across the second resistor (depending on the current) which will reduce the voltage across the horn.You missed the point. Sorry, I didn't state it accurately.
This will 'splain it Lucy.
https://en.wikipedia.org/wiki/Voltage_divider
current will take path of least resistance
For DC current, yes you are correct...but for AC and high frequency...things start to 'act funny'...Current takes all paths, in an amount inversely proportional to their resistance.
That's known as "letting all the magic smoke out"....Electronics run on smoke...once the smoke leaves, they stop working...
