So, I've decided to take a risk using Amsoil's new 0W-20 oil in an engine whose recommended grade is 5W-30. My main motivation is fuel economy. I drive a 1994 Geo Metro which currently gets 55mph, mostly highway miles; my goal is 60. I know there's a lot of debate on the thin oils issue around here, but from what I understand here are some reasons for it:
-Amsoil's 0W-20 is on the thick end and close to 5W-30 specs.
-Conventional 5W-30 oils from the 90's typically sheared close to a 20 weight anyway.
-Synthetic oils have good antiwear additives.
-Try it, do a UOA at 5k, and see what you get.
Reasons against:
-Can shorten your engine life, depending on your engine.
-Can cause more wear, depending on your engine.
-Why not just stay with the recommended grade?
I'm sure there are more pros/cons but those are a few that I remember. What I was wondering is... what should I be looking out for to see if I should change back to 5W-30? Any warning signs/sounds? Or was this all a bad idea to begin with and I should switch back before I hurt something?
For the record, I drive in Oregon, which rains around 3/4 of the year and stays relatively cool in the summer. I never speed--usually I go slightly below highway speeds. There are a few hills around my house that give the car a workout.
Reasons against:
