Used Snap-on PolarTek A/C Machine- worth buying?
As long as you have a place to reclaim the refrigerant in a timely and cost effective manner. You have done more work in the past 19 years than I likely will.
I move often and just don't have anyone to "go to". I don't have the time to play games, so thought to buy this machine.
Now I found out a new requirement. To buy bulk freon, I need to be licensed..to get licensed one has to take a test..I took a practice test and scored 100 percent. Test seemed like a joke, like anyone could pass the test without knowing the material.
I got my 609 Certificate from MACs back in 2007 or so, mostly to be able to buy R12 for my 92 Cavalier. They sent me a laminated card after passing the test. You could buy R134a without it. I bought several 30 lb tanks of R134a some years back and I still didn't have to have a certificate to do so. I still have two full tanks and one with a little left in it so I'm probably set for life.
Does it do R-1234yf? I recently did my first AC fix with a lot of help from some experts here. Looking at My Toyota it only takes like 1.2 lbs of R-1234yf. I think that would be far more temperamental to overfill / underfill vs the older systems it seems?
Maybe post an up to date study guide for the test. With the real questions. :)
I always like the "It is believed" type questions when it comes to this sort of test. :ROFLMAO:
