Use 0W-30 instead of 10W-30.
I have used 0w30 (Pennzoil euro) during cold seasons, I use 10w40 in the summer, I do not notice any difference between the two grades. I recently bought a lot of Castrol euro 0w40 on sale and plan on using it for summer. Worse case scenario I change the oil earlier if shifting gets notchy.
I used 0w30 Mobil 1 auto oil in my RC45... the difference was quicker start ups before warm up with absolutely no difference in clutch performance and no increase in wear...
Technically speaking the consensus among the engine manufactures and builders is 0w is superior because the most wear occurs during start up before warm up so the quickest flowing oil is superior...
Quote Amsoil
60% of total engine wear occurs during cold start up
conditions before oil can circulate through the engine...
Quote Lake Speed Jr certified lubrication specialist at Driven Racing Oil.
“While a thicker viscosity grade is a workable solution, remember that
70 percent of engine wear occurs at start-up, so a higher viscosity
grade actually causes more wear, and we have used oil analysis that
shows this,” says Speed.
Quote 540Rat
"Thinner oil flows quicker at cold start-up to begin lubricating
critical engine components much more quickly than thicker oil can.
Most engine wear takes place during cold start-up before oil flow can
reach all the components. So, quicker flowing thinner oil will help
reduce start-up engine wear, which is actually reducing wear overall."
Quote Frank McCowan, former Electrical /Mechanical Small and Large Equip.
Mech at Washington Metropolitan Area Transit Authority...
Listen to Jim Trainers answer below, it is mostly accurate. most
engine wear occurs during not only the first few minutes, but in the
first few seconds from when the engine is started.
Quote Jim Trainor, diy car maintenance guy
"The oil pressure takes a moment to come up and it takes a moment for
the oil to start circulating. There are bearing surfaces in your car,
called “journal bearings” that are quite literally two pieces of metal
separated by a film of oil that is delivered in under pressure in a
continuous flow. These surfaces do not touch when the engine is
operating normally. Other bearing surfaces, such as cam followers, and
piston rings, do touch but are subject to a continuous flow of
lubricating oil. When you start the car there are a few moments where
the oil is absent from these surfaces. Hence increased wear occurs."
Quote EAA ( Experimental Aircraft Association)
"When we first crank the engine, there's no oil pressure and the
crankshaft cranking speed is pathetically slow. The conditions for
hydrodynamic lubrication simply do not exist. Consequently, there is
metal-to-metal contact between the journal and the bearing, and wear
is inevitable."
Quote SAE
Wear of engine components is affected by lubricant quality and flow
and by the metallurgy of the rubbing parts. Recent studies have shown
that after starting an engine at sub-zero temperatures, more than 6
min elapsed before oil reached all of the rocker arm assemblies of a
V-8 engine. Since this could have an adverse effect on rocker arm and
ball wear, the effects of intermittent and zero oil flow on rocker arm
and ball wear were investigated.
Quote Yamaha
Designed from synthetic and mineral base stocks to provide the best
extreme cold-weather performance possible for all Yamaha Snowmobiles.
Gives extra protection during the critical cold-start period where a
large part of an engine’s wear could occur. It also allows faster
starting than any conventional 5W or 0W grade oil could provide. The
additive package is not found in common motor oils. Yamalube 0W-30
provides optimum low-temperature pumpability down to -40° F (-40° C).
This oil has passed rigorous testing—in fact, it’s so good that even
our factory engineers now recommend it for Yamaha snowmobile models
that specify 5w30.
We are so confident we craft the highest quality powersports oil in
the industry that we will warrant the performance of Yamalube in your
new Yamaha vehicle’s or other qualified product’s engine for 20 years
or 100,000 miles (5,000 hours of operation if no odometer), whichever
comes first.
Would you post the analysis of 0w30 in your rare homologated RC 45? Along with previous analysis showing that there was no increase in wear? You ought to have that information at your fingertips. Dang, you still quote everyone else but conveniently or deliberately don't post your own results.
I would use 10w30, Honda oil in your Honda.
You can use 10w30 Honda... 10w30 Amsoil... 0w30 Mobil 1 or 5w30 Mobil 1 in your Honda RC45 and enjoy same mileage expectations...
The only difference is cost respectively...
$17.99...
$15.89...
$9.00...
$9.00...
BLS, the Mobil 1 0w30 analysis was from 2012, Amsoil 10w30 from 2013. 13 years ago and 12 years ago respectively. Has the formulation changed at all for both oils you are showing?? Is that total of 700 Mi on the sample track use or mostly track use? For 641 Mi and 700 Mi on the samples, aluminum and iron look high on a mileage basis.
Do you have any more recent oil analysis to share?
How is it the more recent dated sample is in the right column? Typically the left side is the more recent sample. Did you cut and paste samples from different reports thus the oddity with respect to sample date format?
My ZRX 1200 with 82,xxx original miles shows higher aluminum on a 5000 mile oil change interval, 40ish ppm. Last OCI's have been Mobil 1 20W50, Mobil 1 10w40 4T and Redline 20w50. It's been attributed to the clutch, and the clutch is as solid as the day I got the bike. Extrapolated yours would be 84 ppm for an oci of around 5,000 miles.
Why do you change the oil so soon, everything about it seems to be in order, TBN is off the charts so to speak.
I don't think in a bike that the tradeoffs are the same as in a much larger engine. The "startup wear" from 10w30 vs 0w30 is likely to be minimal. There are two aspect of motorcycle engines (relative to car engine) that I think make 10w30 much less of a risk:
1) There's a lot less physical volume to pressurize, and
2) The oil is much closer to the points that need pressure.
Given the huge range of RPM of a motorcycle engine, I assume the lube pump is on the regulator for everything but a hot idle.
So I suspect that the real world oil pressure delay at common motorcycle riding temperatures is very small with either a 0w30 or 10w30, and the difference between them is likely to be too small to measure outside a test cell with full instrumentation.
Given that a bike has little to no emission control, I would personally run a full SAPS euro 5w40 or a mid saps 504/507 30 grade oil if the clutch is dry.
Some bikes do have emissions controls. My newest bike has three catalytic converters, and was tuned specifically to pass Euro 5 emissions standards.
Most of the bikes that come to America are vetted in a sense to pass European standards, as there are more bikes sold in Europe of the same models that make it to the United states. Manufacturers not going to do two different things in the tight Market that motorcycles are fighting for a market share.
I supply 0w30 SP Delo to a couple shops that run it as hydraulic and final drive oil (to include wet clutches and brakes).
Been running it for ~20+ years.
Granted cold weather performance is a goal. Gets down to -60* most winters. Summer isn't above 65* often. It was below zero today for an idea. Snow still has another month before it's starting to melt.
While climate matters, ive seen 20w50 have zero wear and 10w30 showing wear.
while thin oil starts and flows quicker, heavier oil does not drain off(it leaves a strong film till flow is functional).
my experience anyway
First of all, it is a very, very rare rider that climbs on a bike in temps below freezing, 32 degrees, 0 C. Some will bundle up and ride in below freezing temps, but very few. That being said, most do not need a 0w or even a 5w oil, as 10w is plenty thin above 32 degrees.
Years and years have taught me to trust and even really like Rotella and after trying it all, I prefer the T5, Semi-Synthetic variety for shared sumps. The only bike I own that asks for a 30wt is my Honda Africa Twin with DCT ("automatic" Dual Clutch Transmission). I use Shell Rotella T5 10w30 in the AT. It runs really smooth, shifts like butter and I can take it to the recommended 4,000 mile OCI without a single concern. In all my other bikes I use T5 15w40. (The Husky 701 is the exception, getting 10w60. I stay with recommendations on this bike as the sump only holds 1.8 quarts and I try to change it every 3k.)
As others have said, oils with a ton of VII's are not a good match for shared sump motorcycles. The very reason I am NOT a fan of Shell Rotella 5w40. It sheared way too fast in many bikes I tried it with.
Only it's difficulty to get 10w30 in my country. I heard fellow people saying mobil EP is rubbish, opt for ESP, hence my question about the grades.
Maybe shop for your oil at a Truck or Heavy Equipment store, instead of motorcycle or auto parts stores. They will have HDEO oils, certainly of the 10w30 viscosity and usually WAY cheaper than $15 a quart motorcycle specific oils. A gallon of Rotella T5, here in the States at WalMart is about $18 a gallon or $4.50 a quart.
