LoL ... down votes don't work. If you don't like what someone says and it bothers you that much, then make a response in a post.
I see these upvotes from time to timeThis hasn’t changed since we went to Xenforo.
You can like a post. Or you can pick one of the other emojis.
There is no upvote.
We are not tracking likes, or total responses, as we first did, by username, because there were some negatives to that “score”.
Safari and Brave on iOS, but I’m pretty sure I’ve seen them on Brave on my windows laptop too. Only on threads that have this little question mark in a circle though. Not sure what that meansVery interesting. What browser?
I think that's only a feature on threads that are started and identified as a "Question". I just did a down vote on a post that showed some up votes, and my down vote subtracted from the up votes. Even did a down vote on one showing "0" votes, and it went to "-1". I of course put the up votes back since it was just a test to see the functionality.I see these upvotes from time to time
https://bobistheoilguy.com/forums/threads/lawnmower-recommendations.355584/
Usually on threads that have this “?”
You only see upvotes in question type threads, which are available, but almost never used.I see these upvotes from time to time
Thank you for clarifying that.You only see upvotes in question type threads, which are available, but almost never used.
The down vote also works. Tested it on a Win10 laptop with Firefox, and also tested on an Android phone. If the vote shows "0", a down vote makes it "-1".You only see upvotes in question type threads, which are available, but almost never used.
When you create a new thread, there are options. Not all forums are setup the same. Some have "Question" and some even have the "Poll" option.So what exactly triggers this "feature"?
Never noticed that before, but I don't start many threads either (and when I do, it is using the new post feature at the top of the subforum).When you create a new thread, there are options. Not all forums are setup the same. Some have "Question" and some even have the "Poll" option.
