B1431 in Baldwin
PART NUMBER: B141
Descriptions : Microlite Full-Flow Lube Spin-on
Contains : Anti-Drainback Valve
20 PSI By-Pass Valve
Fits : Buick, Chevrolet, Chrysler, Peugeot Automotive; Jeep
Replaces : GMC 6439354
Thread : M20 x 1.5
O.D. : 3 11/16 (93.7)
Length : 3 7/8 (98.4)
I.Gskt : G381-A
Here's what a Donaldson xref's to in a Wix ..but the gasket is a little bigger in Wix.
Part Number: 51347
UPC Number: 765809513471
Principal Application: Ford Courier (72-82), Hyster, Komatsu, Merc. Bobcat (75-79), Pinto (75-79), Thermo-King, Yanmar Excavators
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 325
Max Flow Rate: 9-11 GPM
Nominal Micro Rating: 20
Gasket Diameters
Number O.D. I.D. Thk.
15597 2.734 2.430 0.226
Here was the Donaldson that I used in the Wix engine
P555522
Lube Filters Product Attributes
A - OD (Inches): 3.12
B - Thread Size (Inches): M20 X 1.5
C - Length (Inches): 3.87
D - Gasket OD (Inches): 2.45
E - Gasket ID (Inches): 2.15
Relief Valve Setting (PSI): 11-17
Anti Drain Valve (Y/N): Yes
Product Type Description: LUBE SPIN-ON FULL FLOW
Primary Application: THERMOKING 11.5522, J.DEERE,
Primary Application 2: YANMAR
